IceCold4x4 (henceforth known as Fox) finally got around to picking up a new transmission for his ZRX. Due to scheduling and time constraints, we only had one day to pull the motor, swap the tranny and button it all back together. Fox was an ambitious man expecting it to take 6 hours. I was a bit more conservative at guessing we would need 12. We started the day about 12:30 and quickly got to work removing the engine and noting deficiencies that might not pass tech inspection.
(https://uploads.tapatalk-cdn.com/20180515/afcf8cefaad32ef60e341196156e0c48.jpg)
(https://uploads.tapatalk-cdn.com/20180515/2c34d537fdc317c7612284bffea66b58.jpg)
Pulling the motor turned out to be a surprisingly easy affair thanks to a removable frame rail, lift and couple of extra hands. I'll trade beers for strong backs on a motor pull any day of the week.
(https://uploads.tapatalk-cdn.com/20180515/4b56e8295755a87cd19d61cb42dfd513.jpg)
(https://uploads.tapatalk-cdn.com/20180515/975c9bb5a2123a764a4b8f79d916f404.jpg)
With the motor out and turned over we began working on removing the oil pan, oil pump, stator, water pump, clutch and other various accoutrements.
(https://uploads.tapatalk-cdn.com/20180515/0c82fa968b9b522c5b16600dfd4a8484.jpg)
This being a Fox project, we of course were without a service manual. If I can offer one word of advice to anyone considering undertaking an endeavor that involves splitting the cases it's to print out the section of the service manual applicable to your task and reference it early and often. We probably wasted 2 hours on fiddling on how to split the cases, miscommunication and what else need to be removed in order to get to the tranny.
(https://uploads.tapatalk-cdn.com/20180515/798db051ced8b510144882d4104d58e2.jpg)
(https://uploads.tapatalk-cdn.com/20180515/4866c10bc63bd44af5682f70c818ab30.jpg)
(https://uploads.tapatalk-cdn.com/20180515/12a3b180ac781ea15345a93b9d5ef324.jpg)
(https://uploads.tapatalk-cdn.com/20180515/9be776d57a08fdce70d2fd339f141b88.jpg)
By around 6:30, we had the cases split and had identified the problem. Ample hoonery had worn down the dogs on 4th gear and it would slip out of gear with any application of throttle. The pants of hunger and a hangover taking shape, we decided this was a good time to call it and get dinner.
As we wrapped up dinner, Fox received a phone call that a gasket had finally been delivered and went to go pick it up. I prepped the mating surfaces in the interim and lined things up for the new tranny install.
Fox found a gear box out of an 80s ZX-10 and with minimal finagling and mixing of parts it dropped in fairly easily and suddenly he had a sixth gear. Honestly, I was incredibly surprised how well it fit. The actual tranny swap took us all of about 20 mins checking and rechecking our work.
(https://uploads.tapatalk-cdn.com/20180515/5fff25b93300a1fb573df17bdc53ac1a.jpg)
With the new tranny installed we spread a thin layer of Honda bond across the case halves and prepared to mate them up again. Torque specs were followed for the crank bearings but may have been skipped in later stages by the owner. At this point I hereby renounce any liability
(https://uploads.tapatalk-cdn.com/20180515/ac5e24d482c0cf1ec46842805efb090b.jpg)
Reassembly went fairly smooth but we were closing on 10 PM and attention spans we're starting to fade. Fox had been up for roughly 40 hours having driven in from Kansas City that morning and going right to work on stripping down the ZRX for our task at hand. I was coming down with a sinus infection. Mistakes were being made and tools misplaced. Rechecking our work caught a few small things and we both decided that the best course of action would be to button up the engine and resume work tomorrow. We rechecked torquings, made notes on what was missed and bagged left over parts and what pieces the corresponded to.
(https://uploads.tapatalk-cdn.com/20180515/5a18fdef48e49bf62c1e080b8f180a5c.jpg)
Closing in on 11:30 we mounted the engine back in the frame.
(https://uploads.tapatalk-cdn.com/20180515/cba5e2f6bf8980ddac9a894295c58a28.jpg)
And at 12:15, nearly 12 hours after we began, the mighty ZRX was loaded onto a trailer, headed home to get fluids, the carbs and gas tank reinstalled.
All in all, it was an excellent day of work. We met the challenge, adapted and overcame and at no point got into a heated debate that typically goes with these sort of time constrained undertakings. That being said, if we were to ever do it again a service manual print out would have saved a lot of googling and guesswork.
Fox still hasn't buttoned it up yet, but I imagine the first time he shifts through 6 working gears the satisfaction of a job well done will make the lost sleep all worthwhile.
Here's hoping "Do-work" garage has claimed another victory. If not, well volunteer labor - you get what you pay for!
fantastic.
really wanted to be there to show your progress and hide parts.
You were missed! Around 8 hours in Fox said "I can't help but feel like if Kyle were here we'd be done by now..."
I replied with "I feel the same way about a service manual."
Quote from: bblass on May 15, 2018, 03:11:08 PM
:D
Very nice!
Sent from my SM-G900V using Tapatalk
Yea. I still haven't turned another wrench here's hoping this weekend...
But thanks to Ben for the help. Now I've got to pray she holds oil.... Becuase I forgot to order 3 seals! Let's just hope they are good enough.
Great job on walking us through the project. I'd really like to watch something like this in person someday.
Personally I hope that's the last transmission I ever have to pull.
Sent from my SM-N950U using Tapatalk
Glad I could swing by and offer my expert opinion!!
Quote from: Fencejumper09 on May 16, 2018, 08:25:25 AM
An engineer's eye is always helpful!
That is really impressive. I've never, ever even consider splitting a case much less swapping a transmission. I wish I could have been a part of it.
In our delirium Fox and I talked about doing a tech day garage party - little longer than most but an opportunity for those who've never done it come and learn. Something like rebuild a thumper from the ground up with the goal of knocking it out in a day.
Anyone have a project they'd be willing to lend for the cause? Might want to wait on
@IceCold4x4 to post up on whether or not this was successful first!
The KDX could probably use a full rebuild!
Quote from: bblass on May 17, 2018, 11:22:25 AM
You mean like a KTM 450 with a blown head gasket and warped head, that'll probably need a complete new head and crankshaft?
Unfortunately, I just dropped that one off at the dealer yesterday... :(
Ya the kdx would be a good one for a how to make a 2 smoke street legal....
And maybe next time how to install a lightweight stroker crankshaft on the zrx...
Quote from: KevinB on May 17, 2018, 12:11:20 PM
If it's not too late and you want to mess with it Precision Automotive downtown has done some spectacular head work for me in the past. Think they charged me $25 to plane the deck on my CB750. I know they're who big number 1 farms their machine work out to and may be the same people max uses.
New crankshaft is another story but precision can check that too while they're at it. Modern work at 1930's prices; just tell them when you need it by otherwise it goes to the very back of the pile.
Great job guys.
Anyone have a project they'd be willing to lend for the cause? Might want to wait on @IceCold4x4 to post up on whether or not this was successful first!
This is an interesting concept.
I do have any old Kawi 175 in a trailer at the house.
I have no idea what condition the internals are in, but it could be a candidate.
Quote from: LawnmowerRG on May 21, 2018, 01:40:26 PM
Great job guys.This is an interesting concept.
Would be a good way to make a little extra money at Vintagefest! MC-AL Rebuilders!!
I like the "natural lighting" for the pics.
Sent from my SCH-I535 using Tapatalk
This was left out however... I blame lack of sleep (https://uploads.tapatalk-cdn.com/20180521/127c51731d4eb9da2249f84f97d67601.jpg)(https://uploads.tapatalk-cdn.com/20180521/10c871d219d82388fda01ced1aeb8fe6.jpg)
The good news is that just involves pulling the oil pan. Next time we need to stick with our organizational plan. Live & learn!
That sounds terrific! We could have it at my garage or a clinic at The Bike Shop.
We could even start a little less ambitious. I'd wager there's a fair amount of interest in something like a top end rebuild or carb cleaning and balancing.
Quote from: bblass on May 23, 2018, 08:22:57 AM
...top end rebuild...
I'd really like to observe this
I've got an old CB450 that needs to be reassembled. If no one speaks up with a more worthy project I'll post up a garage day for those interested.
I should probably plan for a top-end rebuild on the YZ! Contemplating if I want to Ironman the PM 24hr race or go do the TN Dirt Devil ride for my birthday weekend. HMMM!
when all the parts arrive I'll bring by the kdx in pieces and we can put the magic smoke back in to it
Well it ran today and pissed oil from an external oil hose. But thanks to @kylepeterson all is well. Buttoning up a few cosmetic things and give the coolant another Bleed check but it looks like it will be good to go. Transmission shifted through all the gears on the stand and other than some funny neutral light issue looks good.
