2001 DR650se for $3000
Started by WhiteNoise, July 16, 2017, 04:16:20 PM
WhiteNoise
Posting for a friend. Located in Huntsville and asking $3000. 2001 Dr650se. Unknown mileage because the speedo was replaced with a trail tech unit. Fcr39mm pumper carb with dynojet jet kit. Twin air air filter. Rm250 inverted Kyb forks with a rebuild and skf seals last summer. Off road wheels with a tkc80 on the front and a d606 Dunlop on the rear. Supermoto wheels with very new Dunlop q3 tires. 320mm oversized brake rotors on both sumo and off-road wheels. Steel braided front brake line. Warp9 3 finger levers. Warp9 shift lever. Warp9 adjustable brake pedal. Msr skid plate. Moose racing rear rack. Smaller taillight housing upgrade. Secondary led taillight undertail for more rearward visibility, oil changed recently to Motul 300v full synthetic and a k&n oil filter (will come with an extra oil filter). Oil filter magnet installed. Magnetic drain plug installed. Acerbis 6.6 gallon gas tank and stock 3.2 gallon tank in blue. Protaper fat bars and clamps. Saddleman gel seat in black and extra stock seat in blue and black. Acerbis fork guards. New battery this spring. Led headlight. DG slip on exhaust. New ebc brake pads on front. RK gold x ring chain. Supersproxx stealth twin ring sprocket (the kind with aluminum body and steel teeth so it lasts forever). Double take mirrors. Fresh brake fluid up front. Possibly more than listed. If interested, contact (256)653-2037
Sent from my VS986 using Tapatalk
