'73 Norton bottom end overhaul
Started by norton73, August 26, 2017, 09:35:44 PM
Then I set the timing side case half in the cylinders to make sure the cam was going to engage the cam followers correctly and maybe shim the cam some;
Then, finally, a little Yamabond 4 on the case joints, drop the crank and cam in, and bolt it all up.
KrisCook
2019 Honda Rebel 500
2018 Honda Grom
