broken katoom
Started by rmcelroy, June 24, 2018, 08:42:23 PM
rmcelroy
Well, bike still broke.
I got a fuel pressure tester.  Everything looked good there.  Staying between 45-50psi.  While hooking it up I did find the dunce cap fuel filter and went ahead and replaced it.  Turns out it was at the inlet to the injector housing.
Next I started resistance testing of the coil and plug cap.  The coil tested within spec.  The plug cap did not test well.  Staying at 1 ohm.   Maybe it will be as easy as replacing the plug cap...  I have one on the way...  We shall see
rmcelroy
#16
Turned out to be the spark plug cap... Of all things.l. Replaced it on Friday, and rode a couple hundred miles today.
Glad to hear that you got it figured out!
