0 Members and 30 Guests are viewing this topic.
Thank you LG and RR !
Quote from: merc16 on January 01, 2018, 12:24:27 PM
I'll never get mine to the level of yours Justin. Congrats. Looking better than ever.
Thanks John. Once you flip$ the Duc then the the Black Pearl shall rise to her glory too !
Quote from: merc16 on January 01, 2018, 08:58:17 PM
Lol it'll never be that clean. But some new triples and forks are on the wish list.
Stites triples.....
Quote from: merc16 on January 01, 2018, 09:03:30 PM
Stites triples.....
I'll be doing some zx14 forks so we will see.
Finally got around to installing my Altrider Skid Plate on my Super Tenere. It wasn't bad, just a lot of bolts for all the brackets. Hope it helps protect the oil filter and oil sump well. Also did the 2nd oil change a little early (3300 miles vs 4000 miles) just because I didn't want to have to take this thing back off anytime soon.
Fixed a little oil seep and found some nearly melted wires!!
Continued the winter maintenance on the 690!
Found some more chaffed wires. The engineers at KTM thought they would be fine routed under the battery tray!
All cleaned up!
And sustenance!
Valve check. All in spec!
Preparing for the fuel filter change to come this weekend.
Got the tank drained, about froze my fingers off!
Now that's there is some dedication in these temps !
Rebuilt the front master cylinder on the YZ!
Also figured out why the throttle was a little notchy, there was some grip glue in the housing so I cleaned that up as well! Silky smooth now!!
Finished work early, so I rejetted the DR650 for colder weather and more fuel economy.  Blue needle, 4th from top, down to 150 main.  Performed the work using only what is in my tool roll.
Runs much better, very little popping.  Went to fill up my gas tank with corn-free gas.  Going to see how far I can go on one full tank.
Also installed a pair of Giant Loop luggage mounts.
gulfcoaster
The DR is starting to look Colorado worthy.
