Author Topic: What did I do to my bike today  (Read 46268 times)
Offline Nice Goat
  • Administrator
« Reply #435 on: February 05, 2019, 06:27:34 PM »
Installed Madstad windshield and a fender extender
« Last Edit: February 05, 2019, 06:39:22 PM by Nice Goat »
IBA #63019 - 2019 500 EXC-F (mine) - 2019 KLX 140 (the kid's) - https://nicegoat.smugmug.com/   - Deep thought: "Pie and coffee are as important as gasoline."
Offline Nice Goat
  • Administrator
« Reply #436 on: February 16, 2019, 03:52:36 PM »
Didn’t like the 14/49 gearing ... took too much away from the street manners.  So today I installed a 46T rear.  Changed out the sprocket bolts and nuts for a harder metal, since the OEM nuts were getting a little rounded on the corners.  Had to remove four links since the 114 chain was at the limit of the axle blocks, and 112 is a multiple of 14.  Also changed the oil and filter.  Then went for a little ride around town.
Next I’ll tackle the IMS 4.7g tank install.
« Last Edit: February 17, 2019, 07:11:30 PM by Nice Goat »
Offline Nice Goat
  • Administrator
Re: What did I do to my bike today
« Reply #437 on: February 17, 2019, 07:13:22 PM »
Big tank installed.  Got it done in about two hours, taking my time.
Offline KevinB
« Reply #438 on: February 18, 2019, 05:00:16 PM »
Replaced the clutch dampers on the 450 today.
They were definitely due for replacement...there's not supposed to be any play.
« Last Edit: February 18, 2019, 05:06:39 PM by KevinB »
Offline KevinB
« Reply #439 on: March 04, 2019, 08:02:42 PM »
I lost 6.8 pounds this evening...
Replaced the stock muffler with a titanium one.
 I wasn't looking to replace the OEM muffler, but I found this one used for too good of a deal on one of the FB Africa Twin owner's pages...I couldn't afford NOT to buy it. It's not really any louder than stock, and the dyno graph only shows about a 2hp increase...but any weight shed from this beast helps.
It's made by Laser, but came unmarked...a couple of minutes and $2.99 on Ebay yielded a Taiwanese made aluminum emblem that turns it into a factory Yoshimura/HRC racing exhaust.
I think I'm also gonna leave the pannier racks off and run it in secsay mode for awhile.
« Last Edit: March 04, 2019, 09:13:00 PM by KevinB »
Offline kylepeterson
« Reply #440 on: March 05, 2019, 06:18:13 PM »
i gotta get some them stickers ! MO HP !
Offline Nice Goat
  • Administrator
« Reply #441 on: March 24, 2019, 06:26:49 PM »
Finally installed my Seat Concepts kit.
Offline Nice Goat
  • Administrator
« Reply #442 on: March 25, 2019, 11:32:09 PM »
Installed an Abrams emergency red LED beacon as an auxiliary brake light.
« Last Edit: March 25, 2019, 11:53:16 PM by Nice Goat »
Offline yamahamer
  • Contributor
  • Bark less, Wag more.
« Reply #443 on: March 26, 2019, 08:57:31 AM »
Unboxed new wheels.
Now to pick what tires to run.
Sent from my SM-G920V using Tapatalk
Offline DonJuan
  • Contributor
  • Perpetually in search of attractive curves.
« Reply #444 on: April 19, 2019, 11:29:43 PM »
Replaced the broken plastic from the last trip to the Ridge.
I’ll find out tomorrow if my wiring is ok. Looks tidy, even if it don’t work.
Offline yamahamer
  • Contributor
« Reply #445 on: April 24, 2019, 06:43:23 PM »
The Husky needed to gain 11oz's.
Offline Nice Goat
  • Administrator
« Reply #446 on: May 27, 2019, 01:51:29 PM »
- Spray wash
- Oil change at 296 miles & 8.9 hours
- Reseated bead on rear tire (had a slow leak)
- Replaced headlight bulb (already?)
- Removed useless marketing babble/excess weight
« Last Edit: May 27, 2019, 01:52:38 PM by Nice Goat »
Offline KevinB
« Reply #447 on: May 30, 2019, 06:03:08 PM »
New shoes and an oil change in prep for RFP#15...
Offline Fencejumper09
  • I bet I could wreck that!
« Reply #448 on: June 14, 2019, 07:52:18 AM »
Installed a lift kit on the 990! Thanks @Nice Goat ready to dig into some maintenance!
2002 YZ250 (EG295)
« Reply #449 on: June 14, 2019, 07:53:39 AM »
Also replacing a broken kick start shaft on the YZ 250.
Might be time for a new clutch basket while I am in here!
2002 YZ250 (EG295)
