Motorcycle Alabama
Open House => Tech Talk => Topic started by: KevinB on November 21, 2015, 05:26:32 AM
Title: Denali Soundbomb Split Dual-Tone Horn Install
Post by: KevinB on November 21, 2015, 05:26:32 AM
So I decided to up my game in combatting DWHUA drivers (Driving While Head Up Ass) and ordered the Denali Soundbomb Split Dual-Tone Horn...
http://www.twistedthrottle.com/denali-soundbomb-split-dual-tone-air-horn
Along with the Plug-N-Play wiring kit and Versys 1000 specific mounting brackets...
http://www.twistedthrottle.com/plug-n-play-wiring-kit-for-stebel-compact-nautilus-airhorns
http://www.twistedthrottle.com/denali-horn-mounting-bracket-for-kawasaki-versys-1000lt-15
Taking inventory...
(http://www.pbase.com/kwb377/image/161896713/large.jpg)
Instructions are simple to understand (which is good for me...too many words make Mongo's head hurt)...
(http://www.pbase.com/kwb377/image/161896714.jpg)
(http://www.pbase.com/kwb377/image/161896715.jpg)
What the instructions leave out is that the nose needs to be removed in order to access the OEM horn wiring.
(http://www.pbase.com/kwb377/image/161896716.jpg)
Some guy a lot smarter than me wrote an excellent tutorial on the Versys forum...
http://www.versys1000.com/index.php/topic,15367.0.html
First step once the plastics are removed is to replace the rear mounting bolt on the voltage regulator with the supplied bolt/bracket...
(http://www.pbase.com/kwb377/image/161896717.jpg)
(http://www.pbase.com/kwb377/image/161896719.jpg)
Then install the acoustic unit with the included mounting bolt/nut (I went ahead and attached the air hose)...
(http://www.pbase.com/kwb377/image/161896720.jpg)
Next install the supplied bolt and bracket that will mount the compressor unit. This is for fitting/wiring, as the bolt will need to be removed in order to reinstall the side fairings later on...
(http://www.pbase.com/kwb377/image/161896722.jpg)
(http://www.pbase.com/kwb377/image/161896723.jpg)
And then run the air hose to the compressor. I could have trimmed the hose, but decided to leave enough length in case I decide to use it on another bike in the future.
(http://www.pbase.com/kwb377/image/161896724.jpg)
Now for the wiring harness...
(http://www.pbase.com/kwb377/image/161896725.jpg)
I mounted the included relay near the battery, and ran the power wire to my Fuzeblock to minimize the number of ring terminals attached to my battery.
(http://www.pbase.com/kwb377/image/161896727.jpg)
(http://www.pbase.com/kwb377/image/161896728.jpg)
Snake the wiring under the tank...
(http://www.pbase.com/kwb377/image/161896729.jpg)
Run the horn leads to the front. Factory wires to the horn are red/black = power   black = ground
(http://www.pbase.com/kwb377/image/161896730.jpg)
Now to ground the compressor...
(http://www.pbase.com/kwb377/image/161896738.jpg)
I used this factory grounding point on the frame...
(http://www.pbase.com/kwb377/image/161896739.jpg)
Before reinstalling the plastics, time for a test...
(http://www.pbase.com/kwb377/image/161896740.jpg)
http://vimeo.com/146441385
Fairly unobtrusive once the bodywork is in place...
(http://www.pbase.com/kwb377/image/161896742.jpg)
(http://www.pbase.com/kwb377/image/161896743.jpg)
Total install time was @ 2.5 hours.
Title: Re: Denali Soundbomb Split Dual-Tone Horn Install
Post by: springer on November 21, 2015, 08:08:49 AM
 Excellent how to! Plenty of pictures!
Post by: speedfire on November 21, 2015, 03:56:10 PM
Sounds familiar......nice write-up.
Post by: Nice Goat on November 21, 2015, 04:54:15 PM
That thing is loud!  I love it!
Post by: Shepcam on November 21, 2015, 07:50:04 PM
That should scare the shit of some old lady!
Post by: Chuck A. on November 21, 2015, 11:44:41 PM
Does the relay come with the horn or the harness or is it a separate purchase? Just ordered the horn. Wondering if the Denali will work with just the existing horn wiring or will it require the battery direct wiring and relay.
Post by: KevinB on November 22, 2015, 12:57:03 AM
Quote from: Chuck A. on November 21, 2015, 11:44:41 PM
The relay came with the horn kit. Not sure about using the existing horn wiring...I'm electrically inept, so I just went ahead and ordered the idiot-proof wiring kit.  :)
Post by: LawnmowerRG on December 01, 2015, 07:05:15 PM
Good job. I have been thinking about one of those myself. thanks for the great right up.
Post by: Chuck A. on December 01, 2015, 08:54:42 PM
 Put one of these horns on my 1500 no lead last  Wednesday. It is plenty loud for a horn on the bike.
Post by: Nice Goat on December 02, 2015, 08:27:52 AM
I bought one and went to install it, but the relay is sticking.  If I disconnect the horn, I can hear the relay toggle, but as soon as I connect the horn, the relay sticks closed.  Just need to stop by Autozone for a new relay.
Post by: KevinB on December 02, 2015, 09:31:33 AM
I may relocate mine to the stock horn location under the nose...being under the plastic side cover muffles it just a tad. Still loud, but I want the full "Holy Crap!" effect.  :)
Post by: teambeer on April 11, 2016, 08:01:44 PM
How did you tighten the bracket screw with the left fairing in place.  I can't seem to find a straight path to the screw and with the fairly in place I can't get to it from the side.
Post by: KevinB on April 11, 2016, 09:23:43 PM
I wound up zip-tie'ing the compressor to the tubular engine mount. I installed a set of SW Motech crash bars and they interfered with the entire mount. Before the SWM bars, I just left the bolt out of the fairing mount (using just the lower mount).
