DIY Slide Plates
Started by Fencejumper09, December 15, 2017, 08:00:53 AM
Very nice.  I love watching you folks make stuff for your bikes.
I mostly do it to save money but I ended up spending what a SX Slide plate would have costed had I just bought one. But they don't make them for my year YZ and I have enough material to help a couple buddies make one for their clapped out dirty bikes! I also ended up with a custom fit and shape to protect bit I felt needed it!
It really was a fun little quick project. I will probably do another iteration with some slightly modified coverage but I am happy for now!
That turned out really nice. I've never been one for making my own parts. It looks like all of your wood working tools came in handy for this. I have none of those tools.
Is there a way to heat the material and press a recessed area for the bolts instead of cutting away some of the material? It seems like that leaves a weak point where the material is thinner.
How hot are you getting it so that it will bend easily?
RubyRider
You did a Very Nice Job on Fab'n up that Skid Plate!
Apparently You are Afflicted With some Serious Craftsmanship!
If you aint smokin, you are eatin dust!
I bet we could heat up some washers and press them in. That honestly never crossed my mind but sound like a good use of some of the spare pieces laying around!
Thank you Rubyrider!
How did you heat it? I'm assuming a heat gun maybe? I use a thermo plastic at work, but nothing this stout. I have to heat the entire sheet to get it evenly heated to cut and work with it. It has a pretty low heat point for workability, 140 degrees. I use a large heat pan(like an industrial electric skillet) that I fill with water. Using the heat gun doesn't give me enough working even heat and I end up with a wad of bubblegum that looks like it's been left on the dash of my car in August.
I have a sheet of aeronautics grade lexan that I want to play with for a windscreen. I'm planning to try heating it in my oven to get an even heat for molding.
I used my Harbor Freight heat gun and a propane torch. I used them in conjunction on both sides of the bend, switching every so often.
The oven would work well if you can build a mold! The oven was off limits for me! My wife is already not too happy with the dirtbike! I think a piece of plastic in the oven would push her over the edge. I would come home to a bonfire of motorcycles one day!
Just sayin' 8)
Beer fridge and pizza/parts oven in the garage!
Quote from: Chitza on January 11, 2018, 08:31:53 AM
Just sayin' 8)
I actually have an oven and fridge next to my garage. The downstairs area was built as a mother-in-law suite. I just have to share it with my 8 year old daughter. Luckily she doesn't drink much beer yet.
I wish I had room for that!
I've had mine on for a few rides now. Very happy with how slippery this plastic is. It's survived at least one Axe shaped rock and several case-outs on trees/rocks. Much easier to slide over than aluminum !
Two hose clamps up front and a section notched 45° at the back (like the ktm plates slide into place) into the frame.
Thanks David !
Finally installed my front mounts on my. I just bent some aluminum bar for now around the frame.
The next iteration will have a more refined and easier to mount system!
