LED lights with an ac current
Started by Ryanbroome, November 02, 2015, 01:18:47 PM
Ryanbroome
I found this on motoscrubs.com. I thought it was very helpful on adding a led light to my KTM ac electrical system.
With pictures
http://www.motoscrubs.com/LED_taillights_AC_motorcycle.htm
LED taillights on a motorcycle with an AC electrical system
The problem:
Some of us with old  motorcycles have AC (Alternating Current.) electrical systems.  That means the current flowing through the wires (amps) alternately change direction many thousands of times a minute.
For the purposes of this topic we might as well regard the AC electrical system as an 'alternating voltage' system since it's easier to grasp that concept.
The voltage in an AC system is also unregulated, meaning the voltage at the extreme peaks of the sinusoidal AC voltage wave (its positive and negative peaks) often climbs with engine RPMs.
Light bulbs (not LEDs) are considered "non-polarized" which means they don't care what polarity the voltage is or what direction current flows through them.  Light bulbs will work in positive voltage systems or negative voltage systems, as well as in AC systems where the voltage polarity is constantly alternating polarities between positive and negative.
Light bulbs can be dim at low RPMs, they are susceptible to failure from vibration and so sometimes we would like to "upgrade" to higher brightness and more robust LED lighting in our taillights.
However, LEDs (Light Emitting Diodes) are "polarized" and only run off of DC voltage.  Often times when the voltage of the motorcycle reverses direction, the reversed and unregulated negative voltage suddenly applied to the LED will make the LED fail.  Most LED taillights are designed to use positive DC voltage.
(Only some old British cars and motorcycles used negative DC voltage and those vehicles are said to have a "positive ground system."  We will not cover positive ground systems in this discussion.)
Simplest to install and cheapest LED adaptation to an AC motorcycle:
Most everyone has a negative ground vehicle so this narration presumes negative ground.
The simplest and cheapest way to implement a LED taillight on a AC bike is to half-wave rectify the AC voltage into DC voltage.  In this simple adaptation there is no attempt to regulate the voltage, only to rectify its polarity from AC to DC.  Regulation would require more components and would serve to control the maximum voltage.  Why regulate?  Similar to reverse voltage, too much voltage can also burn out LEDs. But for simplicity's sake we will not try to regulate the voltage at this time.
The simplest rectifier is a "half-wave rectifier,"  Effectively half the power available is thrown away in a half-wave rectifier by blocking the half of the AC system's voltage sine wave.   The resulting power that comes out of the half-wave rectifier is referred to as pulsating DC voltage because the DC will pulse on and off at a very high rate of speed.
A power diode is used to rectify the AC into DC voltage, but the power diode has to be installed in the correct direction so that the pulsating DC voltage becomes positive DC voltage and not negative DC voltage.
A single power diode might cost around a dollar.
Basic half-wave rectifier concept:
We want to run the LED taillight off of positive DC voltage.
The thin line in the following top and bottom diagrams represents your motorcycle's frame which, because it is metal, is used just like a wire in the wiring harness.  It serves as your voltage reference point, or "ground."
In the drawing labeled "AC in" The thick line represents the voltage on the wire going to your running light or to your brake light.  It climbs into the + (positive voltage) region, changes direction and then swings down into the - (negative voltage) region with respect to your motorcycle's frame over and over again..
The triangular symbol represents the power rectifier diode you will be installing.
In the drawing labeled "DC out" The thick line represents how the voltage on the wire going to your running light or to your brake light will appear after rectification.  The voltage climbs into the + (positive) region and returns to 0 volts, then after a while it repeats again, always and only in the positive region.  This is what the LED wants to see: DC voltage.
Implementation:
I hate the thought of soldering wires to the two ends of a diode, wrapping the whole thing with electrical tape or putting heat-shrink tubing around it, and being left with a lumpy-looking aberration in the wiring harness.  Electrical  tape unravels over time and lets water gets in, and sticky tape residue will haunt the wires forever.
While the connection to the diode may be electrically secure, is it mechanically solid?
While the rectifier diode is hidden in the wiring harness, I know it's there, and I have higher standards than most considering I am sort of 'in the business' of automotive and motorcycle wiring.
To make a compact, fully insulated, rugged, water-resistant and electromechanicaly solid "in-the-line" half wave rectifier I used a 1N5402 power diode available from Radi0 Shack at a cost of about $2 for two diodes.
The term "200PIV" means the diode will resist  up to 200 volts of inverse voltage, far more than is needed.
LEDs use very little forward current so the 3-amp rating is also far more than is needed to run a LED taillight, but I chose this diode for its body diameter.  The reason for this will become clear very quickly.
Note the light-colored band at one end of the diode.  That's the "cathode" of the diode.  It's important later.
You'll also need one each of the fully insulated blue-colored .(14-16 AWG)  male and female .250 " Quick Disconnect terminals.
Male                                               Female
The 14-16 AWG size fully insulated terminals are important because the largest wire diameter they are made to accept is about the same as the outer diameter of the diode.
Clip the ends off the power diode's legs to about 3/8".
Push the actual body of the diode into the wire opening of the Quick Disconnect terminals.
  This is what the assembly should look like. You can still see the cathode band through the opaque insulation on the connector; in my case the cathode connects to the Male .250 terminal.
Crimp each terminal in the narrowest portion of the terminal to make a strong electrical connection.  The assembly is done.
No soldering required!
When you go to install this diode assembly you merely cut the wire that needs the diode and put a fully insulated male and female disconnect on the two ends of the cut wire. You'll need to plan which end of the cut wire should get the male terminal and which should get the female terminal based on what terminal you put on the cathode of the diode and which way the diode will be facing when inserted between the cut wire.  That will be covered soon.
Now you'll be able to install the half-wave rectifier power diode in-line quickly, and should you ever need to remove the diode you can take it out just as quickly and rejoin the cut wires by pushing the wire's connector's together.
One power diode or two?
My taillight is in a fiberglass tailpiece, as such the tailpiece is not electrically conductive.  That means  I have to run a wire from the taillight bulb socket's metal shell to the motorcycle's frame.  For this reason I am able to use a single poser diode for half-wave rectification.
If your taillight is mounted in a metal fender or in a metal bracket, that is to say that your wiring harness has only two wires going to the taillight; one for the brake light and one for the running light, with no third wire connecting the bulb socket to the motorcycle's frame, you will need to use two power diodes for half-wave rectification.
Single diode implementation for nonconductive (fiberglass, plastic) mounted taillights:
Dual diode implementation for taillights inherently connected through metal to the motorcycle's frame.
If you ever have to return to incandescent light bulbs, pull out the diode(s) using the quick disconnect terminals and that should leave a male and a female disconnect terminals on opposite sides of the wire such that the wire connection can be immediately reinstated using the remaining .250 terminals.
Caveat:
On my Ducati AC electrical system motorcycle the brake lamp filament grounds the ignition coil to the frame through the brake light switch when the brake pedal is depressed.  I know it sounds bizarre but it's true.  It's too complicated to explain here unless a lot of  people start asking.  If you do this conversion and you step on the rear brake pedal and the engine dies, you'll know what I am talking about.
When performing this conversion I had to:
A) ground the ignition coil directly to the frame,
and
B) change the brake light switch from a SPST (Single Pole Single Throw) NC (Normally Closed) to a SPST NO  (Normally Open),
and
C) connect the "input" side of the brake light switch to the running light circuit.
How can you tell in advance if switching to LEDs is going to kill the engine when you step on the brake?
Pull the brake light bulb out of its socket and while your motorcycle is on the center stand and the engine is running depress the brake pedal.  If the engine dies you're in for steps A, B and C.  If the engine continues to run you shouldn't need to perform steps A, B and C,  Be sure to replace the brake light bulb before you ride the motorcycle.
Disclaimer:
Half-wave rectification may not by itself be sufficient to power an LED taillight from an AC system.  As was mentioned, there is no voltage regulation occurring with this simple rectification.
Simple LED taillights contain biasing resistors to set the amount of current that will flow through the LEDs, and the biasing resistor's value assumes a fixed voltage level, such as a constant 12 volts or constant 6 volts.
When the pulsating DC is below the expected voltage the LED will not light to full intensity.  When the pulsating DC voltage is above the expected voltage level the current passing through the LEDs could be enough to damage, shorten the life span or burn out the LEDs.
What might help is that during half-wave rectification the LED is un-powered 50% of the time giving the LED a chance to cool down.  For some portion of the pulse the voltage will be below the bias resistor's optimal voltage level.  Any over-voltage condition will be very short lived, and it might not do any damage to the LEDs.
Always check your brake and taillight often.  I usually check mine every time I get on my motorcycle and when I get off it.
My half-wave rectifier is working to power my LED taillight without voltage regulation, but I am using a rather high-end LED product that has integral current limiting to power its LEDs:
  Franzen@CuLayer.com
This page might later be expanded to cover such subjects as simple and cheap as possible voltage regulation, and perhaps full wave rectification.
Nice and easy to understand article.
Make sure yo read the disclaimer. You could very easily burn up your LED headlight using an unregulated source. But for a cheap tail light bulb swap its worth a shot.
Ryanbroome
Quote from: Mulley on November 02, 2015, 06:41:11 PM
Absolutely. My KTM regulates the voltage right out of the stator so I should be good right? That's the way I see it at least.
