Author Topic: KTM Dual Sports  (Read 2997 times)
Offline bblass
  • Contributor
  • middling rider, terrible dancer
Re: KTM Dual Sports
« Reply #15 on: May 16, 2019, 08:08:43 AM »
Between Kevin & Glenn I'm salivating over this "coming soon" thread!
Offline rmcelroy
  • Member
Re: KTM Dual Sports
« Reply #16 on: June 27, 2019, 08:09:05 AM »
I gots me one of them there katoom dual sporty machines
Offline Mulley
  • Contributor
  • Stay Dirty My Friends
Re: KTM Dual Sports
« Reply #17 on: June 27, 2019, 02:43:35 PM »
PSA: Summer is here y'all. If you're hot they're hot. Take care of your KTM Dual Sport and keep them cool.
« Last Edit: June 27, 2019, 03:49:24 PM by Mulley »
2015 Versys 650 LT / 2016 Beta 300 RR / Suzuki DR-Z440S
Offline Fencejumper09
  • The Friends > The Ride > The Destination
Re: KTM Dual Sports
« Reply #18 on: June 27, 2019, 03:00:53 PM »
Don't forget to drain them out after they cool down!
2002 YZ250 (EG295)
Offline Gam
  • Contributor
Re: KTM Dual Sports
« Reply #19 on: August 24, 2019, 06:26:25 PM »
I parted ways with the KLR.  790 Adventure S with a high front fender, akropovik and Kenda Big Blocks. I was looking for an Adventure R, but you can't find one, but I am happy with this.
Offline KevinB
Re: KTM Dual Sports
« Reply #20 on: August 24, 2019, 08:51:05 PM »
Offline kylepeterson
Re: KTM Dual Sports
« Reply #21 on: August 25, 2019, 12:08:02 PM »
Re: KTM Dual Sports
« Reply #22 on: August 26, 2019, 10:10:42 AM »
That 790 is SEXY!!!
2002 YZ250 (EG295)
Offline Nice Goat
  • Administrator
Re: KTM Dual Sports
« Reply #23 on: August 26, 2019, 07:45:02 PM »
Very nice, Gam!
IBA #63019 - 2019 Africa Twin - 2019 500 EXC-F - 2019 KLX 140 - https://nicegoat.smugmug.com/   - Deep thought: "Pie and coffee are as important as gasoline."
Offline LawnmowerRG
  • 10% chance of sun sounds like good odds.
Re: KTM Dual Sports
« Reply #24 on: September 26, 2019, 04:47:05 PM »
May have just picked up my next light weight dual sport. 2011 300 XC. She needs a little work. A few of you may recognize it.
Offline Mulley
  • Contributor
Re: KTM Dual Sports
« Reply #25 on: September 27, 2019, 09:34:11 AM »
Very cool and yet very sad. Is this the way Andy left it or has someone else had it?
Offline LawnmowerRG
Re: KTM Dual Sports
« Reply #26 on: September 27, 2019, 10:05:05 AM »
This is the way Andy left it, but someone else has had it. I did some horse trading to acquire it. I need to figure out why Andy took the motor apart. All I know is that it barely finished the last race he ran on it.
The plan is to Dual Sport it. Build your he motor for bottom end torque. I may swap in XC-W gears the transmission.
« Last Edit: September 27, 2019, 10:08:33 AM by LawnmowerRG »
Offline Mulley
  • Contributor
Re: KTM Dual Sports
« Reply #27 on: September 27, 2019, 02:36:18 PM »
XC gears are terrible for the street. Maybe you'll get lucky and it just needs a new piston. How does the cylinder look?
Also, I don't think the XC has a proper stator for running lights. You can get a Trailtech stator with new regulator/rectifier and go full DC system instead of split AC/DC system. I have one on my Beta 300, it works great and it's plug and play.
Offline LawnmowerRG
Re: KTM Dual Sports
« Reply #28 on: October 24, 2019, 04:15:30 PM »
So I have been looking. The only difference in the XC and XC-W according to the micro fish is one tooth in first and second gear. Then the final drive is different. I think I will just split the difference on the final drive ratios and leave it the same inside.
I havent found what was wrong with the motor yet but I have had time to really get into it.
Also the plan is to run a trail Tech stator and rectifier Or BaJa design. Haven’t decided. Probably run a good LED head and tail light/blinkers. Maybe add a small rear rack. May go tubliss too.
« Last Edit: October 30, 2019, 01:28:20 PM by LawnmowerRG »
Re: KTM Dual Sports
« Reply #29 on: October 25, 2019, 01:58:10 PM »
I have found what was wrong with the motor yet but I have had time to really get into it.
it takes about five minutes to swap the front sprocket. i used to go 12/13/14/15 depending on what was coming up next and leave the rear alone. i think i used the 13 tooth the most with the kdx wide ratio trans, just got used to hitting the pipe around 50 mph and stayed below that if i could or got used to the smoke if i couldn't. the hard part were the vibrations. sweet my toes on fire from the vibes
