Bead leak on my tire
Started by LawnmowerRG, December 27, 2019, 07:31:10 PM
I found a new one today.
I snatched off my TKC 80s my BMW today.
Slapped the Dunlop trail smarts back on.
Ran out to do a couple things after work. One stop was about an 1 to 1.5 hours.
When I pulled out I noticed the bike didn't want to turn. Like a flat tire. Then the dash went nuts and was flashing red showing me I had 21 psi in the front tire. Suspicions were confirmed.
I ran back to the shop and broke the tire down. The little molding tits were trapped in the bead part was around the tire. At each one that was trapped I had developed a leak after I had ridden.
I cut all the ones closest to the bead and it appears to have solved the problem.
I hope this helps someone in the future.
2372ighost
Better to find it now than later.
2009 Vespa GTS250IE
2006 Ural Patrol
2011 Suzuki GSX1250 fa
2010 Husaberg FE390
1996 1400 Intruder
